Message Flows
A basic registration exchange with support for PUIs enabled.
From UA to P-CSCF
REGISTER sip:192.168.1.232:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.231:5060;branch=z9hG4bK-13794-1-0 From: <sip:7818888@hxu.com;tag=1 To: sut <sip:7818888@hxu.com> Call-ID: 1-13794@192.168.1.231 CSeq: 1 REGISTER Contact: <sip:7818888@192.168.1.231:5060>;expires=3600 Content-Length: 0
From P-CSCF to Registrar
If reg-cache-route is enabled on egress sip-interface, P-CSCF provides Path support with a value of P-CSCF-contact, so INVITE from core will have route header with value of this path per RFC 3327.
REGISTER sip:192.168.200.231:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.200.232:5060;branch=z9hG4bK0g6tnu200o10tfgl0641.1 From: <sip:7818888@hxu.com;tag=1 To: sut <sip:7818888@hxu.com> Call-ID: 1-13794@192.168.1.231 CSeq: 1 REGISTER Contact: <sip:7818888-rrbgth3ot667c@192.168.200.232:5060;transport=udp>;expires=3600 Content-Length: 0 Supported: path Path: <sip:7818888-rrbgth3ot667c@192.168.200.232:5060; lr> Max-Forwards: 70
From Registrar to P-CSCF
SIP/2.0 200 OK Via: SIP/2.0/UDP 192.168.200.232:5060;branch=z9hG4bK0g6tnu200o10tfgl0641.1 Call-ID: 1-13794@192.168.1.231 CSeq: 1 REGISTER Contact: <sip:7818888-rrbgth3ot667c@192.168.200.232:5060;transport=udp>;expires=3600 P-Associated-URI: <sip:781!.*!@hxu.com> -- wildcard regex Content-Length: 0
From P-CSCF to UA
SIP/2.0 200 OK Via: SIP/2.0/UDP 192.168.1.231:5060;branch=z9hG4bK-13794-1-0 From: <sip:7818888@hxu.com;tag=1 To: sut <sip:7818888@hxu.com>;tag=1 Call-ID: 1-13794@192.168.1.231 CSeq: 1 REGISTER Contact: <sip:7818888@192.168.1.231:5060>;expires=3600 P-Associated-URI: <sip:781!.*!@hxu.com> Content-Length: 0
Incoming Request INVITE from core
For the incoming request from the core to the P-CSCF, if reg-cache-route is enabled on ingress SIP Interface, P-CSCF checks the registered P-CSCF-contact-URI in the top Route P-CSCF-contact-URI, instead of with request-URI.
INVITE sip:7816666@192.168.200.232:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.200.231:5060;branch=z9hG4bK-13800-1-0 From: sipp <sip:3054252165@192.168.200.231:5060;user=phone>;tag=1 To: sut <sip:7816666@hxu.com> Call-ID: 1-13800@192.168.200.231 Supported: 100rel,timer,resource-priority,replaces CSeq: 1 INVITE Contact: sip:7816666@192.168.200.231:5060 Max-Forwards: 70 Route: <sip:7818888-rrbgth3ot667c@192.168.200.232:5060;lr> Content-Type: application/sdp Content-Length: 141 v=0^M o=user1 53655765 2353687637 IN IP4 192.168.200.231 s=- c=IN IP4 192.168.200.231 t=0 0 m=audio 6000 RTP/AVP 0 a=rtpmap:0 PCMU/8000
outgoing Request INVITE
For outgoing Request from access side, the Register Cache entry will be found by reg-via-key, when options ‘reg-via-key’ and ‘reg-via-match’ are set, P-CSCF will have wildcarded PAU checking for allow-anonymous (or registered) verification if option wildcard-puid-match is set.
INVITE sip:service@192.168.1.232:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.231:5060;branch=z9hG4bK-11911-1-0 From: sipp <sip:7816666@hxu.com>;tag=1 To: sut <sip:service@192.168.1.232:5060> Call-ID: 1-11911@192.168.1.231 Supported: 100rel,timer,resource-priority,replaces CSeq: 1 INVITE Contact: sip:781666@192.168.1.231:5060 Max-Forwards: 70 Content-Type: application/sdp Content-Length: 137 v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.231 s=- c=IN IP4 192.168.1.231 t=0 0 m=audio 6000 RTP/AVP 0 a=rtpmap:0 PCMU/8000
