Registration Event Package
If subscription to the Registration Event package (defined in RFC 3680, A Session Initiation Protocol (SIP) Event Package for Registrations) is enabled, the P-CSCF receives asynchronous NOTIFYs from the core reporting registration state changes. Each NOTIFY provides a </reg-info> XML element that reports state changes. A sample XML report is shown below.
<registration aor="sip:user1_public1@home1.net" id="as10" state="active">
<contact id="86" state="active" event="created">
<uri>sip:[5555::aaa:bbb:ccc:ddd]</uri>
</contact>
</registration>
<registration aor="sip:ep_user1@home1.net" id="as11" state="active">
</contact>
<ere:wildcardedIdentity>sip:ep_user!.*!@home1.net</ere:wildcardedIdentity>
</registration>
</reginfo>
If a </wildcardedIdentity> sub-element is included in the <registration> element (as in the second </registration>, the wildcarded PUI is taken from the </wildcardedIdentity> sub-element, and that wildcarded PUI replaces any previously stored wildcarded PUIs in the registration.
In the absence of </wildcardedIdentity> sub-element(as in the first registration), the PUI is taken from the ‘aor’ attribute of the registration element, and the registration cache is left unchanged.
