Node Functionality Per Realm Configuration
To configure a Node Functionality value per realm:
Navigate to the
realm-config
configuration element.
ACMEPACKET(session-router)# exit ACMEPACKET(configure)# media-manager ACMEPACKET(media-manager)# realm-config ACMEPACKET(realm-config)#
Select the ingress realm where calls generate ACR’s whose node functionality AVP will be marked as configured.
ACMEPACKET(realm-config)# select identifier: 1: realm01 left-left:0 0.0.0.0 selection: 1 ACMEPACKET(realm-config)#
node-functionality
— Enter the value to insert into the Node-Functionality AVP when the system sends ACRs for calls that enter the system from this realm. The default is empty which uses the global node functionality value configured in the sip-config configuration element. Valid values are:
P-CSCF
BGCF
IBCF
E-CSCF
- Save and activate your configuration.
