Node Functionality AVP Configuration
To configure a global Node Functionality AVP value:
Navigate to the
sip-config configuration element.
ACMEPACKET# configure terminal ACMEPACKET(configure)# session-router ACMEPACKET(session-router)# sip-config ACMEPACKET(sip-config)#
Type
select to begin configuring this object.
ACMEPACKET(sip-config)# select ACMEPACKET(sip-config)#
node-functionality
— Enter a global value to insert into the Node-Functionality AVP when the system sends ACRs over the Rf interface to an appropriate destination. The default is P-CSCF. Valid values are:
P-CSCF
BGCF
IBCF
E-CSCF
- Save and activate your configuration.
