SIP Method-Transaction Statistic Enhancements
In prior releases, the Oracle Communications Session Border Controller tracks SIP session agents, SIP interfaces and SIP realms on a global level. Only counters that are related to session rates and constraints are displayed.
You can now enable your Oracle Communications Session Border Controller to track transaction messages for specific SIP session agents, SIP realms, and SIP interfaces.
The following SIP methods are tracked for Recent, Total, and Period Max values:
  • INVITE | ACK | BYE | REGISTER | CANCEL | PRACK | OPTIONS | INFO | SUBSCRIBE | NOTIFY | REFER | UPDATE | MESSAGE | PUBLISH | other (unknown)
With this new tracking enhancement, the show sipd command has been updated with a new method argument which allows you to query statistics for a particular method for a given SIP agent, SIP interface, or SIP realm.
SIP Method Tracking Enhancements Configuration
To enable or disable the expanded SIP Method statistics tracking:
  1. In Superuser mode, type configure terminal and press Enter.
    ORACLE# configure terminal
  2. Type session-router and press Enter.
    ORACLE(configure)# session-router
  3. Type sip-config and press Enter.
    ORACLE(session-router)# sip-config
  4. extra-method-stats—Enable this parameter if you want to use the expanded SIP Method tracking feature. The default is disabled. The valid values are:
    • enabled | disabled
  5. Save and activate your configuration.
