IMS-AKA Call Establishment over TCP
For the UE to send a new request into the network and establish a call, a third TCP connection is created using the information configured/generated prior to creating the first secure connection.
![The IMS-AKA Call Establishment over TCP call flow is described below. The IMS-AKA Call Establishment over TCP call flow is described below.](img/GUID-361E0D5A-0715-446E-9E0C-0BBD4D5280AB-default.png)
- If the TCP connection over a secure channel does not exist, the Caller will establish it.
- The Caller initiates the call by sending SIP INVITE from its PORT-UEC to the P-CSCF's PORT-SDS.
- The P-CSCF forwards the INVITE to the Caller. If not present, it will create a secure TCP connection from its PORT-SDC to the callee's PORT-UES.
- The INVITE is then forwarded to the Callee securely.
