tscf-address-pool > address-range This configuration element defines the address ranges for the local address pools for the TSCF application. Parameters network-address The base network address for this address-range. This parameter may be configured with an IPv4 or IPv6 address. subnet-mask Subnet mask used for this address range. Path The full path from the topmost ACLI configuration prompt is: security > tscf > tscf-address-pool > address-range
