set-system-state
The set-system-state command sets the Oracle Communications Session Border Controller as either online or offline.
Syntax
set-system-state <state>
Arguments
<state> Select the system state- Values :
- online—Enable online system state
- offline—Enable offline system state
The offline setting puts the Oracle Communications Session Border Controller into a state where it is powered on and available for administrative purposes, but does not accept calls. Existing calls in progress are not affected.
Mode
Superuser
Example
ORACLE# set-system-state online
