secret
The secret command sets the User and Superuser passwords.
Syntax
secret <user level>
Arguments
<user level> Each user level argument is listed and explained below.- Values:
- login—Set the Oracle Communications Session Border Controller’s user password
- enable—Set the Oracle Communications Session Border Controller’s superuser password
- backup—Set the backup password
- config—Set the configuration password
Superuser
For security reasons, the ACLI does not echo the password information you enter. You will be prompted to enter the new password twice for both commands. The passwords must be 6-9characters including one non-alpha character. No special characters are allowed, for example: #, %, &, *, etc. For security purposes, please use different passwords for the user and superuser accounts.We recommend that you do not change the default User and Superuser passwords on Oracle Communications Session Border Controllers in your lab and testing facilities.
Mode
Superuser
Example
ORACLE# secret login
