save-config
The save-config command saves the current configuration to the Oracle Communications Session Border Controller’s last-saved configuration, stored in flash memory.
Syntax
save-config <type>
Arguments
<type> Chooses the file format for the internal configuration file.- Values:
- standard—Use standard XML as the file format
- non-standard—Use non-standard, legacy XML for the file format
When this command is executed and resources are sufficient, the Oracle Communications Session Border Controller notifies you that the configuration has been saved successfully and the current configuration number will be incremented by one.
Mode
Superuser
Example
ORACLE# save-config
