restore-backup-config
The restore-backup-config command restores a named backup configuration.
Syntax
restore-backup-config <config-name> [saved | running]
Arguments
<config-name> Enter the name of backup configuration to restore<saved> Restore the configuration to the last saved configuration. This is an optional argument.<running> Restore the configuration to the last running configuration. This is an optional argument.Mode
Superuser
Use the display-backups command to view the backups that are available to be restored.Example
ORACLE# restore-backup-config FEB_07.gz saved
