test-translation
The test-translation command is used to test translation rules configured for the address translation feature. This command is also found in the session-router path. Details on its use are found in the Configuration Elements N-Z chapter.
Syntax
test-translation <argument>
Arguments
<argument> The following is a list of test-translation arguments:- Values :
- called-address—Enter the address on which the called rules are be applied. This entry is required.
- calling-address—Enter the address on which the calling rules will be applied. This entry is required.
- show—Show results of translation
- translation-id—Enter translation rules to test
- exit—Exit the test translationUser
Mode
User
Example
ORACLE# test-translation show
