timezone-set
The timezone-set command sets the time zone and daylight savings time on the Oracle Communications Session Border Controller.
Syntax
timezone-set
The timezone-set command prompts the user for time zone, UTC offset, and daylight saving time information. If daylight savings time for your time zone changes start and stop dates yearly, this command must be set yearly.Mode
Superuser
Example
ORACLE# timezone-set
If you need to exit the timezone-set command before completing it, use the key sequence Ctrl-D.
