display-alarms
The display-alarms command displays details about the specific alarms on the Oracle Communications Session Border Controller.
Syntax
display-alarms
Arguments
none
Mode
User
Example
ORACLE# display-alarms
This command shows the current alarms on the Oracle Communications Session Border Controller. Each alarm entry lists alarm ID, task ID, alarm severity code, number of occurrences, when the alarm first and last occurred, the number of times it has occurred, and a description of the alarm.
