delete-status-file
The delete-status-file deletes the reboot status file.
Syntax
delete-status-file
Arguments
none
Mode
Superuser
Example
ORACLE# delete-status-file
This command deletes the /code/statsDump.dat file which retains all system data if the Oracle Communications Session Border Controller has to reboot. This command also removes the contents of the /code/taskCheckDump.dat file which contains system failure information.
