delete-logfiles
Deletes all closed log files in /opt/logs.
Syntax
delete-logfiles [older-than <days>]
Arguments
older-than—Specify if you want all log files older than an indicated age, in days, to be deleted.
Mode
Superuser
Example
ORACLE# delete-logfiles 100
This command presents you with an Are you sure prompt.
