Working with Configuration Elements
Configuring elements involves entering the ACLI path to the configuration element you want to configure, and then entering the parameter name followed by a space and proper data in accordance with the required format.
- select—Used to select a configuration element to edit or view.
- no—Used to delete the current configuration element object.
- show—Used to view the current values of parameters in the selected configuration element.
- done—Used to save configuration changes.
- exit—Used to exit the current configuration element or path to the next higher level.
Creating configurations
Creating configuration elements involves first traversing to the ACLI path to enter configurations. Once you are in the element you want to configure, enter a parameter name followed by a value.
ORACLE(trap-receiver)# ip-address 10.0.0.1 ORACLE(trap-receiver)# filter-level major ORACLE(trap-receiver)# community-name acme ORACLE(trap-receiver)# done
Saving configurations with the done command
At all levels of the ACLI hierarchy, there are several methods of saving your settings and data.
- The done command, which is entered within a configuration element.
- The hotkey <Ctrl-D>, which is entered within a configuration element. This enters the done command in the command line and saves your information.
The
Save Changes y/n ? # prompt appears when you
exit a configuration element without saving your changes . This prompt only appears if you have changed old information and/or entered new information.
Every configuration element contains the done command.
We strongly recommend that you save your configuration information as you work. This ensures that your configurations have been written to the system database.
ORACLE(snmp-community)# done community-name acme_community access-mode READ-ONLY ip-addresses 10.0.0.2 last-modified-by last-modified-date ORACLE(snmp-community)#
Viewing configurations with the show command
We recommend that you view all of the information you have entered before carrying out the done command or another method of saving. Use the show command to review your configurations. Reviewing your settings will give you the opportunity to make any necessary changes before writing the information to the system database.
To view configuration information, type show when you are finished with a line-by-line entry. The following example illustrates the use of the show command before executing the done command.
ORACLE(host-route)# show
host-route
dest-network 10.1.0.0
netmask 255.255.0.0
gateway 172.30.0.1
description Test host route
last-modified-by admin@console
last-modified-date 2014-01-15 17:12:07
Navigating the configuration tree with the exit command
The exit command moves you to the next-higher location in the configuration tree. In addition, when you use the exit command and have not already saved your changes, the ACLI produces the following message:
Save Changes y/n #
When this line appears, the ACLI is prompting you to save your configurations. This prompt only appears if you have changed old information or entered new information.
If you type anything other than a y in response to the
Save Changes y/n ? # prompt, the system will interpret that character as a no response and will not save your work. You must type a y to save your work.
Choosing configurations with the select command
Editing individual configurations in the ACLI involves finding the element or field you need to update, entering the new information, and then saving the element.
To select an existing configuration element:
Deleting configurations with the no command
There are two methods of deleting configurations.
- You can delete the information for elements while you are still working with them.
- You can delete all configuration information for a previously configured element.
For either method, use the no command to clear configurations. Only Multiple Instance Elements can be deleted from the system. Single Instance Elements can not be deleted; they can only be edited.
