Configuring Using the ACLI
This section describes the two ACLI methods available for configuring the Oracle Communications Session Border Controller using line-by-line ACLI commands.
Line-by-Line Commands
Using line-by-line commands, you can target a specific field for editing. Line-by-line commands appear in the ACLI as their name suggests: each argument consists of a parameter followed by a valid value, both on one line.
At any time, you can access either the element menu or the context-sensitive help to guide you. In the following example, you enter values for three parameters, and then issue the show command to check your work. Finally, type done to save your configuration.
ORACLE(trap-receiver)# ip-address 10.0.0.1 ORACLE(trap-receiver)# filter-level major ORACLE(trap-receiver)# community-name acme ORACLE(trap-receiver)# show trap-receiver ip-address 10.0.0.1 filter-level Major community-name acme ORACLE(trap-receiver)# done
