h323 > h323-stacks > alarm-threshold
The alarm-threshold subelement allows you to set a threshold for sending an alarm when the Oracle Communications Session Border Controller approaches the max-calls limit.
Parameters
- severity
- Enter the level of alarm to be configured per port.
- Default: minor
- Values: minor | major | critical
- value
- Set the percentage of the value defined in the max-calls parameter to determine when the
Oracle Communications Session Border Controller issues an alarm
- Default: 0
- Values: Min: 0 | Max: 100
Path
alarm-threshold is a subelement under the h323-stacks subelement. The full path from the topmost ACLI prompt is: .
