home-subscriber-server
The home-subscriber-server element allows you to configure an HSS configuration element with which to exchange information over the Diameter Cx interface.
Parameters
- name
- Name of this home-subscriber-server configuration element.
- state
- Running state of this home-subscriber-server configuration element.
- address
- IP address of this HSS.
- port
- Port to connect to on this HSS.
- Default: 3868
- realm
- Realm name in which this HSS exists.
- watchdog-ka-timer
- Period of time in seconds that DWRs are sent to this HSS.
- Default: 0 (disabled)
- Values: Min: 0 / Max: 65535
- add-lookup-parameter
- Inserts a P-Acme-Serving header into a message sent into the network. The sender of this message must have been verified by this HSS.
- value
- Set the percentage of the value defined in the max-calls parameter to determine when the SBC issues an alarm.
Path
home-subscriber-server is an element of the session-router path. The full path from the topmost ACLI prompt is:
