host-route
The host-route configuration element establishes routing exceptions on the Oracle Communications Session Border Controller for management traffic.
Parameters
- dest-network
- Enter the IP address of the destination network for this host route. No two host-route elements can have the same dest-network field value.
- netmask
- Enter the destination network subnet mask. The network-interface element will not function properly unless this field value is valid.
- gateway
- Enter the gateway used to leave the local network. The gateway field identifies the next hop to use when forwarding a packet out of the originator’s LAN.
The gateway entered must already be defined as a gateway for an existing network interface. - description
- Provide a brief description of this host-route configuration.
Path
host-route is an element under the system path. The full path from the topmost ACLI prompt is: .
This is a multiple instance configuration element.
