switchover-redundancy-link The switchover-redundancy-link command allows you to switchover the physical interface to standby in a redundant link configuration. arguments <slot> Select the slot number to switchover the link from active to standby. Values 1 | 2 Mode Superuser Example ORACLE# switchover-redundancy-link 2
