synchronize
The synchronize command is used to synchronize files across HA nodes.
arguments
spl <filename>—Synchronizes SPL plugins from the /code/spl directory.
lrt <path><filename>—Synchronize Local Routing Tables (LRT) files between active and standby (e.g. synchronize lrt /code/lrt/filename.xml).
Mode
Superuser
