systime-set
The systime-set command sets the system clock.
Syntax
systime-set
The systime-set command prompts the user for the date and time and updates the system clock. The command will not set the system time if an invalid year, month, or day is entered. Attempting to change the date and time on the Oracle Communications Session Border Controller displays a warning message as use of this command could be service affecting.Mode
Superuser
Example
ORACLE# systime-set
