cli The cli command allows you to modify ACLI session terminal settings and “more” options on your Oracle Communications Session Border Controller. Syntax cli ["more" | "terminal-height"] Arguments more Enable or disable the more prompt you see when the output on the screen is larger than the size of the screen. Values: enabled | disabled terminal-height Enter the number of rows in the terminal Default: 24 Values: Min: 0 / Max: 1000 Mode User Example ORACLE# cli more disabled terminal-hight 500
