clear-trusted
The clear-trusted command deletes a trusted ACL entry.
Syntax
clear-trusted [<index> | “all”]
Arguments
<index> Enter the index number of ACL entry to delete
<“all”> Delete all trusted ACL entries
Mode
Superuser
Example
ORACLE# clear-trusted all
Use the acl-show command to identify the index of a specific ACL entry. Use the clear-trusted all command to delete all of the trusted entries.
