tls-global
The tls-global configuration element allows you to configure global TLS parameters.
Parameters
session-caching
Enable or disable the Oracle Communications Session Border Controller’s session caching capability
  • Default: disabled
  • Values: enabled | disabled
session-cache-timeout
Enter the session cache timeout in hours
  • Default: 12
  • Values: Min: 0 (disabled) / Max: 24
Path
tls-global is an element of the security path. The full path from the topmost ACLI prompt is: configure terminal > security > tls-global.
