test-translation
The test-translation element tests translation rules configured for the Address Translation feature.
Parameters
- called-address
- Enter the address on which the called rules will be applied. This entry is required.
- calling-address
- Enter the address on which the calling rules will be applied. This entry is required.
- translation-id
- Enter the translation rules to test. This entry is required.
- show
- Show results of translation
Path
test-translation is available under the session-router path.
The test-translation element can also be configured in Superuser mode as a command.
