ipsec > security-association
The security-association subelement allows you to configure a security association (SA), the set of rules that define the association between two endpoints or entities that create the secured communication.
Parameters
Path
security-association is a subelement of the ipsec path. The full path from the topmost ACLI prompt is: .
