ipsec > ipsec-global-config
The ipsec-global-config subelement allows you to configure establish the parameters governing system-wide IPSec functions and behavior, including IPSec redundancy.
Parameters
- red-ipsec-port
- Enter the port on which the
Oracle Communications Session Border Controller should listen for redundancy IPSec synchronization messages
- Default: 1994
- Values: Min: 1025 / Max: 65535
- red-max-trans
- Enter the maximum number of redundancy transactions to retain on the active
- Default: 10000
- Values: Min: 0 / Max: 999999999
- red-sync-start-time
- Enter the time in milliseconds before the system starts to send redundancy synchronization requests
- Default: 5000
- Min: 0 | Max: 999999999
- red-sync-comp-time
- Enter the time in milliseconds to define the timeout for subsequent synchronization requests once redundancy synchronization has completed
- Default: 1000
- options
- Enter the appropriate option name for the behavior you want to configure
Path
security-association is a subelement of the ipsec path. The full path from the topmost ACLI prompt is: configure terminal > security> ipsec>security-association.
This is a single instance configuration element.
