PreviousNextJavaScript must be enabled to correctly display this content
ipsec
The ipsec configuration element allows you to configure security policies and security associations on your
Oracle Communications Session Border Controller.
Parameters
security-policy
Enter the security-policy configuration element.
security-association
Enter the security-association configuration element.
ipsec-global-config
Access the ipsec-global-config subelement.
Path
ipsec is an element of the security path. The full path from the topmost ACLI prompt is:
configure terminal > security> ipsec.
