ims-aka-profile
The ims-aka-profile configuration element establishes supports IP Media Subsystem-Authentication and Key Agreement, defined in 3GPPr7 (specifications in TS 33.203 and call flows in TS 24.228).
Parameters
- name
- Enter the name for this IMS-AKA profile
- start-protected-client-port
- Start value for the pool of port numbers available following a successful re-authentication. Like the protected server port, the protected client port pool should not overlap with the port range defined in the steering ports configuration using the same IP address and the SIP interface. If there is overlap, the NAT table entry for the steering port used in a call will prevent SIP messages from reaching the system’s host processor.
- Default: 0
- Values: Min: 1025 | Max: 65535
- end-protected-client-port
- End value for the pool of port numbers available following a successful re-authentication. Ensure that this value is greater than the value assigned to start-protected-client-port. Note that the maximum supported pool contains 5 entries. Like the protected server port, the protected client port pool should not overlap with the port range defined in the steering ports configuration using the same IP address and the SIP interface. If there is overlap, the NAT table entry for the steering port used in a call will prevent SIP messages from reaching the system’s host processor.
- Default: 0
- protected-server-port
- Enter the port number on which the
Oracle Communications Session Border Controller receives protected messages; 0 disables the function. The protected server port should not overlap with the port range defined in the steering ports configuration using the same IP address and the SIP interface. If there is overlap, the NAT table entry for the steering port used in a call will prevent SIP messages from reaching the system’s host processor.
- Default: 0
- encr-alg-list
- Enter the list of encryption algorithms
- Values: aes-cbc | des-ede3-cbc | null
- auth-alg-list
- Enter the list of authentication algorithms
- Default: hmac-sha-1-96
Path
ims-aka-profile is an element under the security path. The full path from the topmost ACLI prompt is: .
This is a multiple instance configuration element.
