verify-config
The verify-config command verifies the Oracle Communications Session Border Controller’s current configuration. The verify-config command checks the consistency of configuration elements that make up the current configuration and should be carried out prior to activating a configuration on the Oracle Communications Session Border Controller.
Syntax
verify-config
Mode
Superuser
Notes
The verify-config command, entered either directly or via the save-config command, checks for address duplication for a given network-interface within a configuration. Addresses are checked for duplication based on the following criteria:
- Every address entered is checked against the Primary and Secondary Utility addresses
- All UDP, TCP, and TFTP addresses are checked against other UDP, TCP, and TFTP addresses respectively within the same port range
For detailed information, refer to the Maintenance and Troubleshooting Guide.
Example
ORACLE# verify-config
