watchdog
The watchdog command sets or queries the state of the watchdog timer. If the system becomes unstable causing the watchdog timer to not reset, the system reboots.
Syntax
watchdog <arguments>
Arguments
<arguments> The following is a list of valid arguments:- Values:
- enable—Enable the watchdog timer
- disable—Disable the watchdog timer
- fetch—Display the watchdog timer configuration
The fetch argument can be accessed from user mode.
Mode
User
Example
ORACLE# watchdog enable
