sip-manipulation > mime-sdp-rules > sdp-media-rules
The sdp-media-rules configuration allows you to configure HMR for SDP.
Parameters
- name
- Enter a name for this SDP header rule. This parameter is required and has no default.
- action
- Choose the type of action you want to be performed.
- Default: none
- Values: none | add | delete | manipulate | replace | store | sip-manip | find-replace-all | reject | log
- comparison-type
- Select a method to determine how the header in the body part of the SIP message is compared. This choice dictates how the
Oracle Communications Session Border Controller processes the match rules against the SIP header.
- Default: case-sensitive
- Values: case-sensitive | case-insensitive | pattern-rule | refer-case-sensitive | refer-case-insensitive | boolean
- match-value
- Enter the value to match against the SDP body part of the SIP message. This is where you can enter values to match using regular expression values. Your entries can contain Boolean operators.
- new-value
- When the action parameter is set to add or to manipulate, enter the new value that you want to substitute.
- sdp-line-rules
- Where you configure the list of SDP line rules. See sip-manipulation mime-sdp-rules sdp-session-rules sdp-line-rules
Path
sdp-media-rulesis a subelement under the sip-manipulation>mime-sdp-rules element. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-manipulation > .
This is a multiple instance configuration element.
