sip-monitoring
The sip-monitoring element is used to configure the SIP Monitor and Trace feature.
Parameters
- state
- Administrative state of the SIP Monitor and Trace feature.
- Default: disabled
- enabled | disabled
- monitoring-filters
- List of configured filter names to be applied on a global basis. Multiple filters can be entered in a comma-separated list with no spaces. You may add or remove configured filters on a one-time basis with the + or - key. You may enter a * as a wildcard to filter all session data.
- interesting-events
- Enter the interesting-events configuration element.
- trigger-window
- Time in seconds to reach the trigger threshold.
- Default: 30
- Min: 0 / Max: 999999999
Path
sip-monitoring is an element under the session-router path. The full path from the topmost ACLI prompt is:
