session-timer-profile
The session-timer-profile element is used to configure support for RFC 4028 Session Timers.
Parameters
- name
- The name of this session-timer-profile element. This value is configured in a sip-interface's session-timer-profile parameter.
- session-expires
- The value of the session expires header in seconds
- Default: 1800
- Values: 64-999999999
- min-se
- The value of the Min-SE header in seconds (this is a minimum session expires value).
- Default: 90
- force-reinvite
- Sets if the
Oracle Communications Session Border Controller will send a reINVITE to refresh the session timer when applicable
- Default: disable
- Values: enable | disable
- request-refresher
- Set on the outbound side of a call what the
Oracle Communications Session Border Controller sets the refresher parameter to. Valid values are uac,, uas, or none.
- Default: uac
- Values: nane | uac | uas
- response-refresher
- Set on the inbound side the value of the refresher parameter in the 200OK message.
- Default: uas
- Values: uac | uas
Path
session-timer-profileis an element under the session-router path. The full path from the topmost ACLI prompt is:.
