session-translation
The session-translation element defines how translation rules are applied to incoming and outgoing numbers. Multiple translation rules can be referenced and applied; this configuration element group rules together and allows them to be referenced by a single identifier.
Parameters
- id
- Enter the identifier or name for this set of session translation rules. This parameter is required.
- rules-calling
- Enter the rule(s) defined in the translation rules element applied to the calling number
- rules-called
- Enter the rule(s) defined in the translation rules element applied to the called number
Path
session-translation is an element under the session-router path. The full path from the topmost ACLI prompt is:
The Oracle Communications Session Border Controller applies the translation rules established in this field cumulatively, in the order in which they are entered. If this field is configured with a value of “rule1 rule2 rule3”, rule1 will be applied to the original number first, rule2 second, and rule3 last. This is a multiple instance configuration element.
