sip-advanced-logging
The sip-advanced-logging configuration element allows you to configure advanced logging objects on the Oracle Communications Session Border Controller.
Parameters
- name
- Name to display on the log message for this set of criteria.
- state
- Specifies whether this named instance is enabled or disabled.
- Default: enabled
- Values: enabled | disabled
- level
- Log level for this advanced logging set of criteria. This corresponds to the system's available log levels.
- Default: DEBUG
- Values: ZERO | NONE | EMERGENCY | CRITICAL | MAJOR | MINOR | WARNING | NOTICE | INFO | TRACE | DEBUG | DETAIL
- scope
- The range of SIP messages and, if configured, media for which this advanced logging criteria creates log messages.
- Default: session-and-media
- Values: request-only | transaction | session | session-and-media
- matches-per-window
- The number of matches, within the window size, for which the system generates log messages.
- Default: 1
- Values: An integer between 1 and 999999999
- window-size
- The amount of time, in seconds, to sample for matches within the traffic.
- Default: 1
- condition
- Type this parameter to enter the adv-logging-conditions subelement. Specify the match criteria for which the system creates log messages. Each logging criteria set supports multiple match conditions.
Path: sip-advanced-logging is an element of the session-router path. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-advanced-logging.
This is a multiple instance configuration element.
