sip-advanced-logging > condition
The sip-advanced-logging's condition subelement allows you to configure multiple sets of matching criteria for the associated sip-advanced-logging element on the Oracle Communications Session Border Controller.
Parameters
- match-type
- A string identifying the type of information within the SIP message on which the system attempts to find a matching value.
- Default: recv-agent
- Values: request-type | recv-agent | recv-realm | request-uri-user | request-uri-host | to-header-user | to-header-host | from-header-user | from-header-host
- match-value
- A string the system uses as the matching string within the SIP message.
- If the match-type is "request-type", valid values include:
- REGISTER | INVITE | ACK | BYE | CANCEL | PRACK | OPTION | INFO | SUBSCRIBE | NOTIFY | REFER | UPDATE | MESSAGE | PUBLISH
- For all other match-types, enter the string the system must find in the message.
Path: adv-log-condition is a subelement of the sip-advanced-logging element. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-advanced-logging > condition.
This is a multiple instance configuration subelement.
