sip-manipulation > mime-rules > mime-headers
The mime-headers configuration allows you to configure MIME headers, which operate on the specific headers in the match body part of the SIP message.
Parameters
- name
- Enter a name for this MIME header rule. This parameter is required and has no default.
- mime-header-name
- Enter the value to be used for comparison with the specific header in the body part of the SIP message. There is no default for this parameter.
- action
- Choose the type of action you want to be performed.
- Default: none
- Values: add | replace | store | sip-manip | find-replace-all | none
- comparison-type
- Select a method to determine how the header in the body part of the SIP message is compared. This choice dictates how the
Oracle Communications Session Border Controller processes the match rules against the SIP header.
- Default: case-sensitive
- Values: case-sensitive | case-insensitive | pattern-rule | refer-case-sensitive | refer-case-insensitive | boolean
- match-value
- Enter the value to match against the header in the body part of the SIP message. This is where you can enter values to match using regular expression values. Your entries can contain Boolean operators.
- new-value
Path
mime-headers is a subelement under the sip-manipulation>mime-rules element. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-manipulation > mime-rules>mime-headers.
This is a multiple instance configuration element.
