sip-manipulation > mime-sdp-rules
The mime-sdp-rules configuration allows you to configure HMR for SDP.
Parameters
- name
- Enter a name for this SDP header rule. This parameter is required and has no default.
- msg-type
- Select the message type to which this header rule applies
- Default: any
- Values:
- any—Both Requests and Reply messages
- request—Request messages only
- reply— Reply messages only
- out-of-dialog—
- methods
- Enter the list of SIP methods to which the MIME rules apply, such as INVITE, ACK, or CANCEL. There is no default for this parameter.
- action
- Choose the type of action you want to be performed.
- Default: none
- Values: add | replace | store | sip-manip | find-replace-all | none | reject | log
- comparison-type
- Select a method to determine how the header in the body part of the SIP message is compared. This choice dictates how the
Oracle Communications Session Border Controller processes the match rules against the SIP header.
- Default: case-sensitive
- Values: case-sensitive | case-insensitive | pattern-rule | refer-case-sensitive | refer-case-insensitive | boolean
- match-value
- Enter the value to match against the SDP body part of the SIP message. This is where you can enter values to match using regular expression values. Your entries can contain Boolean operators.
- new-value
- When the action parameter is set toadd or to manipulate enter the new value that you want to substitute.
- mime-header-rules
- See "sip-manipulation mime-isup-rules > mime-header-rules"
- sdp-session-rules
- list of sdp-session-rules. See "sip-manipulation > mime-sdp-rules > sdp-session-rules"
- sdp-media-rules
- list of sdp-media-rules. See "sip-manipulation > mime-sdp-rules > sdp-media-rules"
Path
mime-headers is a subelement under the sip-manipulation>mime-rules element. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-manipulation >mime-sdp-rules.
This is a multiple instance configuration element.
