sip-profile
The sip-profile configuration element allows you to configure SIP profiles on the Oracle Communications Session Border Controller.
Parameters
- name
- Enter a unique identifier for this SIP profile. You will need this SIP profile’s name when you want to apply this profile to a realm, SIP interface, or SIP session agent
- redirection
- Set this value to specify the redirection action, within the context of SIP Diversion interworking.
- Default: none
- Values: inherit | none | isup | diversion | history-info
- ingress-conditional-cac-admit
- Set this parameter to enabled to use conditional bandwidth CAC for media release on the ingress side of a call. Set this parameter to inherit for the value to be inherited from the realm-config, sip-interface, or sip-interface
- Default: inherit
- Values: enabled | disabled | inherit
- egress-conditional-cac-admit
- Set this parameter to enabled to use conditional bandwidth CAC for media release on the egress side of a call.
- Default: inherit
- forked-cac-bw
- Select the method for the CAC bandwidth to be configured between the forked sessions.
- Default: inherit
- Values:
- per-session—The CAC bandwidth is configured per forked session
- shared—The CAC bandwidth is shared across the forked sessions
- inherit—Inherit value from realm-config or sip-interface
- cnam-lookup-server
- Enter the name of an enum-config to query ENUM servers for CNAM data.
- cnam-lookup-dir
- Set this parameter to ingress or egress to identify where the system performs a CNAM lookup with repsect to where the call traverses the system.
- Default: egress
- Values: ingress | egress
- cnam-unavailable-ptype
- Set this parameter to a string, no more than 15 characters, to indicate that the unavailable=p parameter was returned in a CNAM response.
- cnam-unavailable-utype
- Set this parameter to a string, no more than 15 characters, to indicate that the unavailable=u parameter was returned in a CNAM response.
- replace-dialogs
- Enables the
Oracle Communications Session Border Controller to process messages with the Replaces: header. It also adds the replaces parameter to the to the Supported header in the realms where it is applied. The inherit value falls back to the higher level of configuration precedence.
- Default: inherit
- inherit | enabled | disabled
Path: sip-profile is an element of the session-router path. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-profile.
This is a multiple instance configuration element.
