PreviousNextJavaScript must be enabled to correctly display this content
sip-q850-map
The sip-q850-map configuration element is used to map SIP response codes to q850 cause codes.
Parameters
entries
Enter the entries configuration subelement
delete
Delete a SIP to q850 mapping. Enter the SIP code.
edit
Edit a response map by number
Path
sip-q850-map is an element under the session-router path. The full path from the topmost ACLI prompt is:
configure terminal
> session-router
> sip-q850-map
