PreviousNextJavaScript must be enabled to correctly display this content
sip-q850-map > entries
The entries subelement is used to create the mapping of q850 cause to SIP reason code.
Parameters
q850-cause
Enter the q850 cause code to map to a SIP reason code
sip-status
Enter the SIP response code that maps to this q850 cause code
Values: Min: 100 / Max: 699
q850-reason
Describe text to accompany the mapped SIP response code
Path
Entries is a subelement under the sip-q850-map configuration element, which is located under the session-router path. The full path from the topmost ACLI prompt is:
configure terminal
> session-router
> sip-q850-map
> entries.
