sip-recursion-policy
This element defines a sip-recursion policy that is applied to a session agent or session agent group.
Parameters
- name
- Name for this SIP Recursion Policy. This value will be referenced by individual session agents' or session agent groups' sip-recursion-policy parameter.
- description
- A textual description of this SIP Recursion Policy instance. If the description includes spaces, enclose all words within double quotes.
- global-count
- The maximum number of recursions to take before terminating recursion and sending the response back to the requester. Entering 0 here disables a maximum recursion counter.
- mode
- The method of considering subsequent responses from one SIP peer containing identical response codes.
- Default: consecutive
- Values:
- consecutive - Stops recursion after the response code is received the attempts number of times, consecutively.
- absolute - Stops recursion after the response code is received the attempts number of times in total, counting from the first reply.
- sip-resp-code-attempts
- Typing this parameter accesses the sip-response-code subelement.
Path
sip-recursion-policy is an element of the session-router path. The full path from the topmost ACLI prompt is
