enforcement-profile
The enforcement-profile sets groups of SIP methods to apply in the global SIP configuration, a SIP interface, a SIP session agent, or a realm.
Parameters
- name
- Enter the name of the enforcement profile.
- allowed-methods
- Select a list of SIP methods that you want to allow in this set.
- Default: None
- Values: INVITE, REGISTER, PRACK, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER, UPDATE, MESSAGE, PUBLISH
- sdp-address-check
- Enable or disable SDP address checking on the
Oracle Communications Session Border Controller.
- Default: disabled
- Values: enabled | disabled
- add-certificate-info
- List of one or more certificate attribute names to enable TLS certificate information caching and insertion of cached certificate information into customized SIP INVITEs. This list is entered enclosed in quotes with attributes separated by spaces.
- certificate-ruri-check
- Set the
Oracle Communications Session Border Controller to cache TLS certificate information and validate Request-URIs.
- Default: disabled
Path
enforcement-profile is an element under the session-router path. The full path from the topmost ACLI prompt is: configure terminal > session-router > enforcement-profile.
