enforcement-profile > subscribe-event
The subscribe-event subelement defines subscription event limits for SIP per-user dialogs.
Parameters
- name
- Enter a name for this enforcement profile.
- event-type
- Enter the SIP subscription event type for which to set up limits. You can wildcard this value (meaning that this limit is applied to all event types except the others specifically configured in this enforcement profile). To use the wildcard, enter an asterisk (*) for the parameter value.
- max-subscriptions
- Enter the maximum number of subscriptions allowed
- Default: 0
- Values: Min: 0 / Max: 65535
Path
subscribe-event is a subelement under the session-router path. The full path from the topmost ACLI prompt is: .
