password-policy
The password-policy element configures password rules for password secure mode.
Parameters
- min-secure-pwd-len
- Enter the minimum password length to use when system is in secure password mode. The maximum allowable length for any password is 64 characters.
- Default: 9
- Values: 6-64
The password using this minimum length value must contain at least one punctuation mark and two out of these three requirements: upper case letter, lower case letter, number. No special characters are allowed, for example: #, &, @.Note:
This parameter is ignored when the password-policy-strength parameter is used (the Admin Security and/or Admin Security ACP license is active). - expiry-interval
- Specifies the maximum password lifetime in days.
- Default: 90
- Min: 1 / Max: 65535
- password-change-interval
- Specifies the minimum password lifetime.
- Default: 24 hours
- Min: 1 hour / Max: 24 hours
- expiry-notify-period
- Specifies the number of days prior to expiration that users begin to receive password expiration notifications.
- Default: 30 days
- Min: 1 day / Max: 90 days
- grace-period
- Time after password expiration user has until forced to change password.
- Default: 30 days
- grace-logins
- Number of logins after password expiration the user has until forced to change password.
- Default: 3
- Min: 1 / Max: 10
- password-history-count
- Specifies the number of previously used passwords retained in encrypted format in the password history cache.
- Default: 3
- Min: 1 / Max: 10
- password-policy-strength
- Enables the enhanced password strength requirements provided by the Admin Security and/or Admin Security ACP license.
- Default: disabled
- enabled | disabled
Path
password-policy is an element under the security path. The full path from the topmost ACLI prompt is:.
