ntp-sync
The ntp-sync element sets the ntp server IP address for correct and accurate time synchronization.
Parameters
Path
ntp-syncis a top-level element. The full path from the topmost ACLI prompt is: .
In order for any changes to the NTP synchronization functionality to take effect, a save-config must be performed followed by a system reboot.
